After just one week and 900 miles I am loving the wing more and more each day. It is my daily commuter and weekend escape pod.
Every day after dinner, my 10 and 5 year old daughters ask, or should I say demand, a ride. Each of them gets at least a 15-20 minute ride through the neighboorhood and local park. ATGATT.
Few observations on the wing.
Power band is as wide as Texas. I have never had to down shift to avoid shudder or lack of power. This big gal just rumbles right along. 3rd gear around town and it is just like an automatic.
The VTX would jerk hard if you rolled on the throttle in a low gear while coasting, or closed it too quickly. Had to feather the clutch often to avoid bumping helmets with the passenger. Wing has no signs of that what so ever.
200+ miles between gas stops. Loving that.
Very few things about the wing that annoy me, and I can learn to live with them all.
I am fairly tall, 6'3" and I feel like I am looking down on top of the guages and control panels. Wish I could take every display and tilt it up a few degrees so I could look straight on to them.
Long legs will require a handle bar riser soon. Tight turns and I have to be sure to move my knee out of the way for fear of the handlebars hitting them and restricting the turn unexpectedly.
Brakes are very very good. Still getting used to them biting so hard, so quickly. Almost wish they didn't grab as well as they did. It is not bothering me as much as it used to. Good brakes are a good thing!
Still occasionaly honk the horn when trying to hit the turn signal, or thumb the starter when setting the cruise control No fault of the wing, just need to get used to it.
The navigation system must be activated and set prior to being on the road. It absolutely refuses to let you adjust the route, or create one while you are moving. If you can adjust the audio panel while moving, you should be able to navigate as well. At least navigate to stored favorites or look for POI's such as a gas station.
Riding position is becoming more familiar each day. I still have the feeling though that my rear end is sliding forward instead of sitting down and back. Have to re position once in awhile to avoid feeling a little crunched through the crotch of the pants.
Confused about which accessories will fit on the 2012 model. Some are obvious they will fit, but when the description says 2010 and below, it makes me wonder.
Buddies still give me cracks about riding an old man's bike, but I shrug them off. Nobody will understand the pleasure and joy of riding a wing until they own and ride one of their own. And I don't want to switch bikes for a 50 miles so they can find out.
I get asked often by people if they can ride it and I have to refuse. I am just not comfortable with handing over the keys to my girl over to just anyone.
500 mile ride down to Houston in a couple of weeks. Should have the trailer setup by then, curious to see how it handles. Somehow I feel that I won't even know there is a trailer behind me.
