1 - 20 of 34 Posts
So I need my first oil change , Im at 4000 miles , the dealer said drop it off and they can get to it within the next 4-5 days HUH? 4-5 days , need to get a jiffy lube for motorcycles , wish I could wrench it my self but I suck at wrenching
If I can do it.....so can you!!!! 45 minutes tops
Hey Gordo, it's a snap. Start off with 4 quarts (we've just been through this already) of her favorite motor oil and dim the lights to set the mood. It will be the first for the both of you so fumbling around is alright. You'll be nervous but take your time...
To insure a quality experience for the both of you....refer to the instructional video.:D
an oil change is one ofthe easiest things you can do yourself gordo and most auto parts store will take the old oil for free
Discussion Starter · #7 ·
Do I have to remove the Bra off the front?
Did you get the 12v power outlet yet ? Did I mention that I do a free oil change with every accessory or bling purchased ?
Discussion Starter · #10 ·
i did order them Lee , just waiting for them to show up at my door
You can do it Gordo. Takes about 30 mins and your done. Only special tool you will need is the filter wrench. Should be able to find at Wally World or local Pep Boys or Auto Zone. If I can do it, anybody can do it...
Shhhh. I'm trying to get a 12v power outlet out of this. Don't listen to him GORDO. I would be skeptical of any advise given from a member who takes his bike to the repair shop to have his tire pressure checked.
Well Gordo, you gonna at least let us know you are going to try?
Hmmmmmmm.....Let's see....Ride the wing from Bama to Virgina for an oil change......Hmmmmm......might be do able some time in the future.....LOL.
Discussion Starter · #16 ·
Sorry , I answered this question on face book just forgot to reply on forums lol, I will be changing my own oil this Sunday
Good for you Gordo....If you have any problems all you got to do is ask all your friends on here......Let us know how it goes.
you know you've done it right if after doing the oil change and running the motor no oil is comming out the motor :)
I don't have one of the wrenches but I have a cap that fits over the filter for changing and works with a 3/8" ratchet. Its pretty snug and sometimes I use a channel lock or vice grip to grip the end of a ratchet. Also if you use an aftermarket filter sometimes you will find two filters that will fit (a short and a long). I usually use the short to make it easier.
Good for you GORDO, but I just have to feel bad for chopin114:p OK, maybe not that bad...
1 - 20 of 34 Posts
