I don't know Joe, on my 93 the OD light don't come on till you are in 5th. The cruise lights come on when the key is first turned on but not the OD.
If you got small hand you might be able to get your fingers back under the dash enough to get the bulb out. Remove the panel around the Key and the space filler plastic in the fork tub next to the left fairing pocket.. If you decide to remove the dash replace them all. It's not a hard job just involved. Windshield has to come off, the radio panel pulled back, which involves removing the seat.. Time consuming job.
From the Northwest corner.
Ron
