1 - 3 of 3 Posts
Has any experienced a non-shut off of a 2002 GL1800? Mine did it yesterday when trying to get gas and it just would not shut off with key. Once I got home had no more problem. Anomaly?
The only time I ever seen anything like that happen , was on a 1500 and then solenoid A was stuck close and kept power applied to the starter circuit.
Was it the starter or the actual engine still running? If it was the engine and it does it again, try turning the high beams off or on after you turn off the key. If it dies, then there’s an issue with the ground circuits in the fairing harness behind the gauges or at the their connectors under the left fairing pocket. If it was the starter, then you need to replace the starter relays A & B soon, before it burns up your starter.
1 - 3 of 3 Posts
