Just got a 1995 Aspencade. The front speakers work fine but I do not get sound from the rear speakers. I do not see a fader control knob anywhere. Is it hidden somewhere? Any help would be much appreciated.
Thank you,
Doug
The Aspencade did not come with rear speakers. It is an after market thing,
Thanks Joe. It has the multi tiny whole openings at each corner of the rear which makes me think there would be speakers in there but maybe I am wrong and it is where I can add speakers?
Sandy
Those are a place to mount speakers. You will need a pass control adapter and two speakers. They plug into the existing harness under the seat.
Thank you Lonewolf. Any suggestion on best place and which speakers to get?
J&M speakers seem to work the best--- as for the fader control any location that is easy for you to reach is fine--- I have see them mounted beside the key switch and in the left pocket---even a slider mounted on the left handel bar
Discussion Starter #8
Ok, will look into J&M speakers and a fader control. I believe the headsets in my helmets are J&M.
Thank you So-Cal.
Doug
