Hello All,
I have a 1993 GL1500SE with about 110K on her. I have two other older wings at it is really nice to have one with reverse. The reverse gear works just fine but when I take it out of reverse the neutral light does not come on. The bike goes into neutral just fine but no light. The big issue is that one I turn the bike off I cannot start it again, even with the side stand up and the clutch bar pulled. To then get the bike started I have to roll it around and start it in gear with the clutch pulled and sometimes it works and sometimes it does not. I ride it around a couple times this way and suddenly I once again have a neutral light... that is until I use reverse again. Sensor somewhere worn? Adjustment needed? Help!
Thank you
Thank you
