That tire on the left has almost 20,xxx miles on it. It is around 6 years old. He asked me if I thought he should put his new one on? Then I found that his brake pads were done. Inner wore more than the outer (slider friction). He will be getting all fixed up. Brakes flushed, pins/sliders cleaned and lubed, splines even look good. That will be cleaned and re-greased with the moly 60 paste. Even getting the final drive oil changed. We will be doing timing belts, front brake/clutch fluid change, fix his kury highway pegs (slipped down), and loose windshield.
