Don't know if you saw these, but here's few of the better videos that show how to get bike up on center stand - main thing is to get the bike standing straight up on the stand feet.Thanks, I looked at a couple of vids, and I see how. I think
Another trick, using the suspension setting. A higher setting makes it easier to place on center stand.Hey Everybody,
I can't seem to get my GL 1800 up on the center stand. Is there a trick to this I'm missing?
Definitely not a stupid question! I struggled getting it up on the center seeing myself a few months ago as previously I had an ST 1100 that was only 650 lb. The best way is to step on the center stand with your right foot and swing your whole body weight to the rear of the bike. The key is to keep your body as close to the bike as possible while doing this . Let me know how you make outHey Everybody,
If you can't park on a totally level surface, be sure to always park facing the up-hill direction. Even the slightest down-hill condition makes getting the bike up a monumental task.Hey Everybody,
Drive rear tire up 0n a one inch board, makes it easierHey Everybody,
This is really the key. Step on the foot plate for your center stand and make sure both of it's feet are touching the ground and the weight is centered. Any amount you are off center will exponentially magnify the effort need to get the bike up on the center stand.Be sure when you have the bike balanced on the center stand and attempting to pull it back the front wheel is straightahead. If not the front tire will drag and it’s almost impossible to get it up on the stand.
Takes a little practice ......after a while it gets easierThanks, I looked at a couple of vids, and I see how. I think
I had a heck of a hard time getting my 2005 wing up on the center stand the first time I tried. I found it much easier after I took it out of first gear, true story!Hey Everybody,
Lmao....go to you tube. And it will show few tricks, practice it and its easier and easier ...I had a heck of a hard time getting my 2005 wing up on the center stand the first time I tried. I found it much easier after I took it out of first gear, true story!
If you got it up on the center stand while it was in gear, remind me to never get you upset with me.I had a heck of a hard time getting my 2005 wing up on the center stand the first time I tried. I found it much easier after I took it out of first gear, true story!
