...About how Honda achieves firing three coils on two pulsers?
each coil fires two cylinders
Ya, that I got, most multi-cylinder bikes are wasted spark systems. The question is, how do they operate three coils on two pulsers?
There's the trigger wheel attached to the crank shaft and the pulse generators 'read' the tooth as it goes by and sends a signal to fire the coil.
trigger wheel?
Also, if you have an '88~'90 1500 wing you can get an aftermarket trigger wheel..it advances the timing by 4 Deg.
Simple to install and if you're changing your timing belts...**as you should if you don't know for sure when ( if ) they have been done**, you're already in there anyway!
This does away with the off idle "stumble" that those yrs had. Only about $35 for the wheel!:)
