1 - 10 of 10 Posts
I have a 1800 wing and I am looking for a economical way to raise my riding height by 2 to 3 inches so that I can take some of the bend out of my legs when using the standard foot pegs. I am 6ft 1inches tall but i have a longer lower torso. Any suggestions besides custom seats
thanks,
Jeff, I'm surprised no one has put this in here already. Check into the forward control kit from Trikeshop/Roadsmith. They're not just for trikes. They move your foot forward and lower. Expensive, something like $600, but if it gets you the comfort (and safely) you want, then well..... One potential problem might be dragging the lower pegs in hard turns.
I think a couple of our members have them. Hopefully those guys will be along soon.
Another possibility for you is seat pads. But you'll only get about a 1" rise before you start to feel like your sitting on a basketball.
Good luck.
Gel Pad
A Gel Pad might get you and inch or so. Put two together? Certainly could meet the inexpensive criteria.
I'm the same height with a 36" inseam. The stock seat really only would bother me on long (66 mile) days. I used an Airhawk pad occasionally and it would help. It sits you up about an inch. I changed out my seat that lets me sit back a couple inches and I really like it.
Have you got aux highway pegs or boards on your Wing? The alternate position helps lots.
I would consider the Roadsmith Comfort Controls if they were so expensive and there wouldn't be any ground clearance concerns.
thanks,
Here is another fix that dosnt cost $700.00.
http://www.bigbikeparts.com/TradePoint/Item_View?itemNo=52-659&catalogNo=1and http://www.bigbikeparts.com/TradePoint/Item_View?itemNo=21-520&catalogNo=1
These do offer some welcome relief and I know some folks really like them, but just a word of caution - they will cause peg scraping on a lot of non-aggressive turns. I tried a set but found I was scraping on every outing and not in twisties of any kind - just flatland driving. The other downside I found was that they also moved my feet outward an inch or so so that I was having to reach in for the brakes and shifter. Like I said, I know there are some who like them, but I took mine off.
I have the Comfort Controls and I can definitely say they do make a difference in your foot/leg position in that you're now in a more 'natural' sitting position instead of having your legs/feet tucked up under you.
Now as far as clearance. I have a trike so that's not an issue for me. I'd suggest you call Roadsmith and pose your question to them regarding the clearance on a two wheeler. Supposedly it's not an issue.
1 - 10 of 10 Posts
