Just bought a 2010 Wing w/ comfort. Is there any way to use the bar controls to operate an Ipod? Also I will be purchasing a portable g.p.s. How do I connect a power supply for this? Can I get the voice of the unit to come through the stereo speakers? Any advice would be appreciated!
http://wingstuff.com/pgroup_detail/.../?goto=/pgroup_list/gl1800/23929_BikeMP3/mfg/
If you plug your GPS into the AUX plug in the left pocket you can hear it through your headset, Power it with the power supply under the left pocket also, Both these connectors are in the same wire pouch under the pocket.
Here is the power plug you need for the GPS or anything else you want to power up
http://wingstuff.com/pgroup_detail/...GL1800_Universal_Electrical_Connection_Power/
This might be a big help to you
Her is the power supply under the left pocket, One plug is for the AUX and the other is for the power. click on picture for larger view.
The power outlet is suppose to be mounted in the pocket, I just laid it under the pocket once I connected it because I was not going to use it for anything else but the GPS so I saved space in the pocket. If you get a GPS that can hold MP3 songs than you can eliminate one device. Play the songs through the GPS to your headset.
Welcome Motohed. Try J&M for a controller for your Ipod, and there may be an interface for the GPS from them too. I'm not the greatest techno geek in the world but J&M John may be able to help.
