Okay I bought all the stuff to install my Zumo 660 on my 2008 GL1800, using a RAM mount on the clutch reservoir. I noticed two screws in the fuse box by the battery for accessories. The Zumo motorcycle cable actually reached the fuse box running the wire under the fairing. I was surprised how relatively easy things were going even though I did scrape up my hands a bit running the wires. I went to loosen the screws on the fuse box to connect the wires and I couldn't get them loose. I started to mess up the philps heads so I stopped. I verified the correct size screw driver. I can't believe these things are in that tight. Does anybody have any good suggestions on how to loosen them.
Thanks,
Penguin
Thanks,
Penguin
