Just cost me @267.00 to replace panel at dealer. Why, well cause thats the Honda way I guess.
That's Hal's site. Here you go :http://www.directlineparts.com/last night took panel off and switch out took it apart cleaned it up now its not stuck on any more but it dose not lock to keep 4ways on at least i can ride now whats HDL and were can i find them
I too took my panel out last night. It was an easy job, I removed the glove box and the fairing trim piece. Then I removed the one screw holding the panel in and there are only 2 connectors that completly remove it from the bike. I then went to the kitchen table and carefully dismanteled each switch (Hazard and fogs). (Be very careful not to lose the spring when you pry the switch open) The hazards were sticking on and the fogs were sticking off. I cleaned each switch inside and out with contact cleaner and lubricated. On the fog switch I had a bit of a hard time figuring out what the problem was but eventually found that the copper connect that bridges the gap actually has a very smal spring under it and this was gunked up. Once I freed it up it was fine. Reinstalling the panel was also pretty easy to do and both switches tested fine.last night took panel off and switch out took it apart cleaned it up now its not stuck on any more but it dose not lock to keep 4ways on at least i can ride now whats HDL and were can i find them
