1 - 2 of 2 Posts
1 Remove the screw through the bottom of the housing. You'll need a good phillips screwdriver, the factory screw has loctite.
2 Wiggle the mirror while pulling it toward you. It will slide out eventually. On the bench the factory mirror is on the right.
3 Mirror housing with mirror removed.
4 From the front of the motorcycle, peel back the rubber boot to expose the wires and connector.
5 The wires are long enough to pull out in order to install the supplied harness. You have to lift the catch on the factory connector to disconnect it.
Continued in part 2, am allowed to load only 5 files (pictures).
Nicest thing about this is you don't have to actually remove the mirror mount from the bike. There's rubber grommets that are easily dropped and lost. Don't ask how I know:rolleyes:
1 - 2 of 2 Posts
