1 - 2 of 2 Posts
Hi,
A few of you guys have installed the Michelin Run-Flat tire, I believe the size is 205-16.
Could you tell me the Michelin model number, where you got it from, and especially, how it rides? My concern is obviously cornering, where you need good road contact.
Did you install Dyna Beads when it was mounted?
My other solution will be to go with a Bridgestone dual compound tire, if they make one for this machine. I have Dunlops on mine, and I have 15K on the rear tire using Dyna Beads, and I will easily get 17K before I have to change it out.
Discussion Starter #2
I'm trying to figure out the proper size for the Michelin rear tire. Do you guys know what it's supposed to be for the CT?
1 - 2 of 2 Posts
