1 - 20 of 23 Posts
I think I will when this tire wears out.
Want to come change mine? ;)
was that “Irish“ coffee? ?
Reactions: Cantankerous
Anybody remove the rear wheel of an 1800? I know I've seen mention of guys laying the bike over on the right side and pulling the wheel, but I'm thinking that's a 2 man job. One to hold the brake lever and one to undo/redo the lug nuts. I'm thinking a second body would come in handy setting the bike up again...grass surface and all that...
It definitely is a two woman job!!
I've done it myself a couple of times, but not on grass. A second person to help get it back upright is definitely a bonus.
Sent from my SM-G950W using Tapatalk
Reactions: budoka
A few years back, a buddy of mine bought the Harbor Freight Motorcycle tire machine and he said we could change the REAR tire on my wing since I was going Darkside, I figured why not, we’ll give it a shot!
Holy crap that job was a bitch! Even bent the machine trying to do it, I decided from that day forward I would pay the man and have it done at the shop! :oops::poop:?
Nicely done Dustin
I did mine on the center stand. It took quite awhile being my first time. I had to remove the center section between the 2 panniers, the framework and a box I think holds the amp. An impact wrench with a swivel will fit to remove the lugs. Torquing the lugs was no problem with it in gear. I have a NoMar tire changer. Not too bad but I'm still learning technics to this machine.
I have the Pakit Rack on mine and don't want to remove it if I can help it. Been on there for years now and would likely be worse than the wheel to take off. Reckon I'll find out come spring
Discussion Starter #13
1800 rear is a piece of cake, I did it by myself when I mountted a car tire by hand.
I do believe that you got all the good out of that front tire. It also looked like another set of hands would have come in handy. I'm a bit disappointed you didn't call me so that I could help you drink your beer.
Discussion Starter #15
I did that at about 1:30 AM, had a early morning ride the next day. Thats why coffe and not beer in the video.
So how did you remove the lugs with no one to hold the brake? I don't have a swivel ratchet so clearance may be an issue for me? Total rookie on this and I can't lay the bike over in the garage to check it out. I'm going to get through it, but I have some worries about it.
Do
You could tie the hand brake lever against the throttle grip to hold it if you don't have an impact wrench. The front and rear brakes are connected yes? If memory serves you'll have to use a swivel.
On second thought my torque wrench fit just fine with a deep socket to put them on. If you have a breaker bar that would work also.
Thanks guys. I know it will be a learning experience, just trying to save some pain in the process.
I used a 1/2“ Matco air gun with a deep socket to remove the lugs on the rear wheel.
i also jacked it up with a pit bull motorcycle jack.
Reactions: JKWinger
1 - 20 of 23 Posts
