these seem to be popular, I had one. They are also popular on craigslist for $75 around here.
Hadn't tried it on a wing but it was "SCARY" on my 1100 shadow. In fairness, it has a bend in the frame and had to put a thick shim to balance.
It does work.
Maybe others here have a different opinion.
what i did not like:
can't strap as you lift. straps are placed after it's up.
It has rubber pads and it gives you a false sense of it sticking in place with the straps pulling it down.
I had my 600 lb bike up on it and secured with 4 straps. Decided I wanted to turn it around for better lighting and carefully began to steer it around in the garage. I was slow and careful. The floor was smooth and assumed the bike was tightened down withe the straps to move. About half way , I nearly lost the back side of the bike off the lift. the far side, front tire caught the bench but I couldn't feel it, the lift kept turning but I realized the bike wasn't. It nearly slid off. I was holding the bike trying to decide whether to run and let it fall or hang on. Couldn't stop to look underneath to see how bad it was. And best of all, I still had complete the turn. I hung on and eventually slid it back onto the lift. Actually, it slid pretty easily on the rubber pads when I put my foot against the lift to keep it from rolling.
It went on craigslist next day.
