HELP!! Has any of you changed your crankcase oil to find that four quarts is not enough to fill the case to the marks on the stick? I changed oil and filter, then added 3.75 quarts. I ran the engine for a minute or so then let it sit for a couple of minutes, and checked the level. I expected to have to add a little, but there was NONE on the stick. I checked for leaks (of course) and everything was clean and dry.I added the rest of the fourth quart, and got the same results. My garage floor slopes slightly toward the door, so I turned the bike around and repeated the level check. Same results.
Have any of you experienced this? Is the quantity in the owner's manual, and the $100.00 service manual both wrong?
What the hell?!? Please advise a.s.a.p.
Thanks,
unclebill
Thanks,
unclebill
