I would guess 30 hours to disassemble. Some of that is breaking down small parts that are bolted to each other, chrome to painted plastic. Even the foot heater ports take time to disassemble and keep screws springs etc. organized.....That includes all the rear console so I could install new speakers.
I am also guessing- 50 to 60 hours to reassemble. Some things got done twice. Fairing was one of them (wiring harnesses in the proper holes etc) It was hard to see some things until I put it on and then saw how cables, wires or order of events became clear. No doubt, someone with experience would have done it in half the time.
I used a Toyota service manager (good friend's friend) to paint it. The tri-coat is very popular and expensive. Also, many colors can't be touched up, the entire part comes off and gets totally repainted.
I ended up picking a Ford color that looks like tri-coat but actually a single coat that can be touched up without disassembly. German paint, pretty expensive to me. $400 quart. He promised it would hold up against bumps, nicks, time and weather better than many paints out there.
BTW, I ended up with parts covering half the living room, one entire bedroom and finally rented a 5 x 10 storage room for all these stuff coming and going or sitting and waiting for reassembly. I could not believe it could all hang on that da#n frame.
Painter also repaired some lower metal parts that were beat up. Filled in the chew marks on the front fender from previous owner's dog. Did it all with clearcoat and then pinstriped over the old pinstripe. $1350. He also said not to quote it to anyone else, it would be more next time.
On last thing, someone told me I could fill in cracks, holes with various glues or paste. He told me that paint would not cover it the same nor would it bond as well. Also, heat and cold would expand and contract different than the ABS plastic. So he filled in the bad places with a plastic welder and ABS rod.
I spend maybe 600 on new plastic. The right shelter was over 300. No way around it to do it right. Chrome wasn't bad. I still need to replace or polish the engine covers.
As for other things while I was waiting:
timing belts
spark plugs
all fluids
all filters including both cruise control filters
4 speakers
went back later and did these and should have:
tires replaced
aggressive wheel cleaning
brakes front and rear
fixed reverse gear (it was just a freakin' loose bolt)
