1 - 12 of 12 Posts
I've a simple question. When I pulll my wing into my garage the antennae hits my garage door. Can I just remove the plastic cap at the top and cut 1-2'' off and replace the cap, or are there wires in there that will be damaged? I know I can use that gizzmo and drop the antennae to 90degrees, but I don't want to do that every time i go in and out ?
Had the same issue on my HD Ultras.
Never bothered me-just entered/exited slowly!
If it's an AM/FM antenna-shouldn't bother reception much to cut off enough length from it.
If it is a CB antenna or an AM/FM/CB antenna, do not shorten it as that will affect the SWR for the CB!
I'd use the slow entry/exit method before cutting the antenna. If you shorten the antenna you affect the flex in the whip (wire) part of the antenna which makes it more susceptible to bending.
Mine strikes the garage door upon entry and exit, I simply fold it down and then set it back up, its no bother to me.
I must have an extra tall garage door.. My antenna does not come any where near hitting.
DeanW,
I wanted a shorter antenna a while ago. Posted similar question in this forum. Joe in Ca posted a link (same as this thread). I bought the short rubber antenna for AM/FM off eBay. Shipped quick and went on in minutes. Looks much better than the OEM giant whip. It works fine for AM/FM radio. I don't have a CB but the seller has one for CB use also.
Thanks Joe for that link!
Rob
Swede,
I did not test the OEM against the short rubber antenna from eBAy, but in my location it works OK for most AM/FM stations when I am crusing about. The guy selling them has a decent return policy if you don't like it. I would not hesitate if you are on the fence.
. My experience with shorter flexible antennas is they work well in close range to the transmitting staion, but their efficiency fades as you get farther away much quicker than the longer metal antennas. Now that being said, that's going back a good many years so they could be much better now.
Nope, only if you buy an after market one..
1 - 12 of 12 Posts
