Was going to put in a matching lock to my others, switched ignition but lock I had didn't fit there. Brushed off the dust and dirt, lubed it, and closed it back up. Now is locked shut. Think I know what I moved in there but can't get back in. Is there a way to open the trunk? Am thinking, hoping, if I remove bottom cover I can get at it. Am I right?:confused:
Manual has it
I don't have my manual with me but, having read it more than once, I know the answer is there for you. If not, I'm sure someone on this forum will come up with your answer.
Sorry for the non-answer answer.
What year Wing??
Once more Joe to the rescue!
Remove the cover on the bottom of the trunk and if you crank your neck around enough you'll see the latch bar/rod hook it and pull it down and the trunk should open. also I put a ty-rap on the bar/rod and tucked up inside., where i can reach it with out removing the bottom panel. If I ever loose a key or some how lock the key in the trunk I can at least get into with out tools.
From the Northwest Corner.
Ron
