Make sure all those HarborFright(misspelling intended)jacks and other variations of same have Grade 8 bolts in them!
Do you really want to trust your approx. $20,000 bike to a $100 jack!
or a $400 table for that matter!
I do trust my bike on this lift.
I agree that the buyer should beware and I am skeptical on things made in China; however, I inspected mine for design and tip over concerns as well as materials used.
I cannot find a reason not to feel confident with it. Even a grade 2, 8mm bolt takes about 4000 lbs of force to deform it. (a 8 mm is about the size of a 3/8 bolt)
A lift typically has 4 points where the weight is distributed. That means the weight is equally divided by 4.
All that together means about 220 lbs is weighing on each point that has the ability to withstand 4000 lbs. ( and that is deformation not shear).
I believe the structure is sound, the hydraulic jack is more than adequate and the safety bar is about an inch thick. If used properly, it is not possible to drop a bike or a car on this lift.
The real concern is tip over where the weight tips to one side causing the lift to flip. This applies to all brands and designs.
That is why I sold my small one that rolls around for this one even tho' it was rated at 1500 lbs.
Like another posted, I am tired of laying on the ground to change oil and clean tires. I use mine for my bike repairs, cleaning and for the lawn tractor as well. I park my bike on it everyday so it doesn't take up space in the garage. And when I need a table, I back off the bike and lift it up. It works for me.
If I quit posting then maybe all this was bs
