Well I spent most of today on the trunk of the Bike..I took out the side lights...fiund a broken wire..took the bulbs out ...pulled the wires and copper contacs out of the socket....drilled the 2 holes out to the size of my heat shrink....bought some ultra bright white LED'S and some resistors 1/4 watt 650 ohm soldered them in line soldered that to the factory harness bent the LED so it was facing the lense...and wola it works....was having a fine day until i shut the trunk... and i did'nt have the latch assembeled right
...was able to remove the bottom of the trunk and ended uppopping it opean......That was a lesson well learned LOL tomorrow the side compartments....
