1 - 3 of 3 Posts
This problem is strictly cosmetic. Lights (the Hondaline kit) went on per instructions and work fine. When I reinstalled the cowl, I find the lights are a little off center - they are are little bit high. (Not TOO high mind you - the light output is not obstructed.) There is no way that I can see to adjust the orientation of them since the bolts go straight into the block. Cowl went back on with no problems and all bolts lined up fine. Any advice?
I have the same kind and guess what.....same results. There has got to be a reason...say...possible the way the light gets out without the cowl reflecting it back. I just don't know, but everyones is the same, and I had frankly just forgot about it. But you are right there is no way to adjust it out.
Mine look the same on my 09. Honda lights also.
1 - 3 of 3 Posts
