Gentlemen,
I just purchased a Kuryakyn cup hold for my GL1500. I have played with different ways to mount it and I'm still not happy with the way I mounted it on the handlebars. Any suggestions or pictures of the way you have mounted cup holders?
Not much to play with, it goes on the left side or right side, mounts to the two bolts that holds the levers on. :rolleyes:
What's " not " to like about it ? I have the Kury cup and holder without the basket , and the black plastic ring. It's fine but very specific about the shape of the container that it will hold. No water bottles will work and a Starbucks mug I wanted won't work because it is not tapered enough. Is it the mount specific that you don't like or the container options it will hold ?
Discussion Starter · #7 ·
I finally settled on the method to mount it and have enjoyed my morning coffee on the 42 mile ride into work once again. I enjoy having my coffee once again. I did find that you need to keep the cap closed or it will splash out if you hit a bump.
The only thing I dislike about it is the nut for the ring stud is right against the CB controls. I cant remove the ring.
Over all I like it.:eek:
