I am going to take the wing down to Zephyrhills, FL. to a place called "Just Wings". Getting air filter, coolant change, brake and clutch fluid change. They only work on Goldwings. Greg the mechanic comes highly recommended. Going to hang out in Tarpon Springs while he works on bike. Great location for Greek food and sponges! Will probably run up to Homosassa Springs to see the manatee's on the return trip. I will let you know how things turn out with the mechanic.
Sorry this update has taken so long. I was very pleased with the service I received at "Just Wings". I had the clutch and brake fluid changed, new air filter, change coolant and replace steering head bearings with tapered bearings. He also lubed hand levers, side stand, cleaned battery connections, checked battery and charging system, checked final drive, check and measure brake pad wear, check vent cables, reverse, throttle cable and all lights. He found a rubber bumper missing and replaced on side cover and a messed up allen head bolt that the dealer must have messed up installing the driving lights. Greg Peterson the owner uses all OEM Honda fluids and parts. I will be taking the bike back at 32,000 miles for the vale clearance check. He also pressure tested the coolant system for leaks.
My wife recalls that there was a doughnut shop or something in the same strip mall or just down from it. We took the wing down on a trailer for two days of work and drove over to Tarpon Springs for a Greek lunch. We stayed at a Hampton Inn nearby.
I'm really glad you posted this as well as your follow up post about being pleased with the service.
We're snowbirds and live in Zephyrhills from November til April.
Now I know where to go for any service that I need.
Regards
Greg
Related Threads
Honda Goldwing Forum
511.5K posts
21.4K members
Since 2008
