My 1996 Wing just quit on me the other day coming home from work. I've done some searching and I think this may be an old problem. It did this before (stranded 5 hrs from home) and I thought the alternator went bad and wasn't putting out enough juice at high rpm to run the fuel pump so I bought a new Compu Fire. Problem went away but has returned. Following the shop manual's test sequence I can get the fuel pump to work when the ECM is disconnected, but not when it is. WHADA YA THINK? ECU bad?? or should I keep looking?
Fuses are all good..
May I suggest checking for an open in the wiring harness that connects the ECM to the fuel pump. Disconnect the harness from the ECM and the #21 pin with the Black/Blue wire and disconnect the same wire from the fuel pump and check for continuity in the harness.
Also run a continuity check from the #14 Gray wire of the ECM harness to ground @ green wire connector to fuel pump.
Have you made sure that the wire connectors are seated in the plastic housing and are clean and tight?
Just guessing here...but maybe you need to check the BAS. If you have a manual I think there is a test in there for it.
May I just say that I understand absolutely none of this :eek: but God bless those who do :) and can be of assistance.... I hope you get your bike fixed...:D
Sorry Charlie......(Geez I have always wanted to say that...LOL).....I forgot that not everyone knows the mechanic lingo.......BAS = Bank Angle Sensor. If it was going bad it would act like as described above and shut the engine down. Turning the key off and on several times will reset it.
If the sensor is malfunctioning it will show up in the readings and they are taken at the green & red/white with 0 to 1 volt and the white & green with 10 to 14 volts. By following the directions and tipping the relay 49 degrees left and then right the #6 relay should open and cut power to the fuel pump.
ferhinehart, let us know when you get it figured out. Then I'll know what to look for when my '01 has that many miles on it. Its only got 37k now... But ya, I'd check that BAS next.
My money is on the ECU being bad. I had the same problem and I decided to replace the ECU, pulse generators, coils and wires, and spark plugs. After I replace all of this the wing cranked fine. I decided to while I had it apart to put the old ECU back in and when I tried to crank the wing it would not start. Swapped out the ECU and it fire up on one push of the start button. At least I know I have new pulse generators and coils and wires.
