As some of you may know, I recently picked up a 1986 Aspencade with about 50k miles. I got it from the original owner who parked it about 7 years ago.
I flushed the tank and found no garbage/gunk or other things. I cleaned the almost new spark plugs and installed a new fuel filter/fuel lines/air filter. Changed the oil and filter. I installed the new Honda filter and Honda oil that came with the Goldwing.
I primed the oil by cranking it with the kill switch on for 5 seconds off 10 seconds. After a few times of that I pulled the choke and started her up. I held it at about 2k rpm and it was doing ok. I turned it off after about 30 seconds to check it out and found a good soze leake coming from cyclinder #1 (right front). With the fairing/covers on I can't see exactly where it is coming from.
The plan is to remove the lower fairing and start it again to id the leak location. Any ideas-sugestions-experiences would be appreciated greatly. Thank you
