I've just had my '83 1100 GL for about 6 weeks. It's been below freezing here for the last couple of weeks so I haven't had a chance to ride it. It finally warmed up today and so I started it up just fine. Then my jacket sleeve must have caught the kill switch. I pretty well ran my battery down before noticing that. I put the charger on my battery and charged it up but all I get is the solenoid clicking. I put the voltmeter across the battery and have 12.6 volts, but I know that doesn't mean much. I thought maybe I had a dead spot on my starter so tried the hammer trick. Then the starter started spinning but wouldn't engage the engine. I also have a starting position on my charger and tried that briefly, and either it clicked or the starter spun. I think I'll have to pull the starter to see what's happening. Anyone have any ideas?
First, welcome to the forum. Sorry your first post has to be a problem. I'm not a wrench guy, but I thought the problem might be the battery not being fully charged but now that you say the starter spins but nothing happens I think you are going to have dig deeper. Sorry, I can't be of more help, but there are others on the board who can and I'm sure will give you some good advice. Good luck..
Starting Issue
Thanks for the welcome. I've since looked at the old service manual and it says you can run a wire from the positive terminal of the battery to the positive terminal of the starter. I could only find the one terminal and I assume that it's grounded through the body. If the starter doesn't work, then it's the starter. So I get no response on the starter when I do that. So it could still be the battery, but I also tried it briefly with the starter function on my battery charger and still no response. It has to be the starter. At least there seem to be lots around on eBay.
hello and welcome to GWOF awdyck
Glad you found your problem. Now go ride.
Discussion Starter · #8 ·
As I said in an earlier post, if you run a wire from the positive terminal on the battery to the terminal on the starter, the starter should turn over. If nothing happens, you've got a bad starter.
