ok here is what i have done.
changed oil and filter,adj valves, adj points, install timeing belts,cleaned carbs and set float(done the washer under the needle trick),flushed gas tank,replaced fuel hose, rebuilt petcock,new tires and tubes,rebuilt all 3 calapers(pads were fine),fresh brake fluid,new neck bearings, checked wheel bearings,changed fork oil,new k-n air filter,changed antifreez,checked all lights(all work),it starts and runs fine on the kick stand and in the yard, no oil or water leaks, fan comes on after about 15-20 min,have i forgot anything, am i ready to ride????
