Whilst killing time waiting for delivery of my new wing next week, i decided to do some shopping for accessories to fit at Wingstuff. I looked in the suspension section and came across this item from Traxxion, they described the wing as follows
They make it sound that the bike is totally useless, i took mine for a test ride before i signed and i thought i rode beautifully. Am i missing something? or is this hypo advertising
andIt's true the Honda Gold Wing is the most sophisticated motorcycle ever created in history. I am sure every Wing owner is baffled as to why their suspension works so poorly. If you are tired of the bouncing, wallowing, bottoming, chattering, wobbling of your stock forks, then TRAXXION DYNAMICS has the CURE!!!
Your stock Showa forks have a "damper rod" in one side and an extremely low quality cartridge in the other side to control the movement of the wheel. The damper rod side is basically useless. This style of fork is used for cheap production parts. Trying to compare a damper rod fork to a proper cartridge fork is like trying to compare a carburetor to fuel injection. There simply is no comparison. The damper rod fork is the cheapest, poorest performing system of damping, and has been around the motorcycle business for so long nobody seems to be able to remember.
The "cartridge fork" came along about 20 years ago in sport bikes, and since has been highly refined. Unfortunately for Wing owners, none of that refinement has made it into the cartridge on the ONE side of your bike!
The next problem is your stock fork springs. The stock springs are so weak and wimpy that they can't even hold the bike up; never mind that they are completely unable to hold you up when you get on it, or take a passenger along. Just pick your bike up off the side stand sometime and watch it collapse before you even get on!
The result is a fork that bottoms over large bumps, wallows in high speed turns, dives dramatically when you pull the brake, cups and tears up your tires, and leaves you generally feeling uncomfortable and lacking confidence in the feel of your bike.
