Install the trunk on 2021 non tour Goldwing
1252 Views 25 Replies 12 Participants Last post by  pcwins
Hi all, Looking for advice. When I bought my 2021 GW, the one without the trunk, I lost a ton of luggage capacity I had on my Kawasaki Concours-my helmet fit easily in a saddle bag. Anyhooo, I want to have the color matched, uber expensive trunk installed. The previous owner had added a few googaws, grip covers (I 86'd those immediately), the gold strike highway foot rests, meh, the center stand YAY! and a luggage rack. I'm assuming some body part was removed to add it, what I'm hoping is that, that will not affect it's removal and installation of the trunk. Has anyone else done this, had it done? Appreciate any help, I really need more luggage capacity.
Bethany
1 - 20 of 26 Posts
I know there ae a couple of you tube videos on how the work goes
I posted one on here in this same reference
Since you say,
it would be helpful if you could post some pictures so I/we could actually see if something was removed and what that something might be. IMO this is needed before I can tell you what you need to do to add the trunk. Oh, the trunk can be added for sure, it's just that the devil is in the detail$
2
Tire Wheel Automotive tire Vehicle Automotive lighting
See the rack on the back tail. These are the only pics I have without a bag on the back 🙃
Tire Wheel Fuel tank Vehicle Automotive lighting
See less See more
Reactions: 2
I want to add one of those to my 2022 DCT non tour so I've looked this up already. Here it is new Rear Carrier Rack for 2018+ GW
Here's an installation video for that rear carrier
2022 Honda Goldwing Rear Carrier Installation
this is can be easily removed and wouldn't prevent you from moving forward with your project. Nice bike by the way!
Reactions: 2
Thanks. Yeah it's a nice rack, but I really need more luggage capacity. I went from a Kawasaki Concours with two huge side bags, and a 52 liter Givi top box. Most of my rides are 10-14 day long mileage. I need my stuff.
Are you trying to put the Tour trunk on your non-Tour?
If so I inquired about do this to a non-Tour that sitting on showroom floor and was told the cost was “about $10,000”.
Not sure how truthfully that is as dealer may have trying to discourage me from doing that.
MotoSewGurl... you said, "what I'm hoping is that, that will not affect it's removal and installation of the trunk". It will not affect that removal and installation.
Special Wing, I don't know why someone would tell you that, he/she is either grossly mistaken or, for who knows what reason, is trying to discourage you because it just isnt true. It's gonna cost in the $2500 range, not cheap, but not $10k
Reactions: 1
I really like the concept of Trunkless until needed. But I might not use a trunk. Instead I’d use a waterproof soft bag that is expandable. I believe more items could be stowed in a soft bag than a hard trunk.
Reactions: 1
I would like to know what dealer said 10K as well. I already talked about with the dealer last year and was quoted in the $2,500 range. 2K of that is just the parts. Thanks all for the input. I was really hoping to find a good video of someone installing one. I’m pretty mechanical but some things are best left to the shop. I’m just not convinced either way on this one. Thanks.
one thing to consider is the stock supports under the plastic on the baggers are just sheet metal that has been stamped into shape.
So Auburn are you saying it's not as 'strong' as a Tour model? I don't know and I don't have an opinion or information on this... just curious.
I was thinking of adding thid rear carrier to my Non Tour DCT and I noticed the weight limit is 6.6 lbs!!
I don’t believe so. Unless Honda includes parts to replace the stock pieces on the bagger. Or Honda will put severe weight restriction on the top case.
If it bolts to the stock bagger pieces, then I would not trust the set up with my wife on the back leaning against the backrest on the tour top case.
Bethany
Try a GIVI 1172 rack for a fraction of the price, easy to install, and various sizes of GIVI boxes will fit the rack.
Reactions: 1
You have the same problem, the Honda OEM pieces under the plastic are flimsy sheet metal (14 gage) pieces with the only structural support being the bends in the metal. It won't support much weight at all especially a weight that is being bounced around and vibrating while going down the road.
I gave that some thought, I’ve had Givi boxes on several bikes. I think I just would like the cohesive look of the color matched trunk. Thanks
Reactions: 1
Bethany
I went with the GIVI option, I like having the flexibility of removing bag on long trips or when I am just running out - it was a 20 minute install, it is rally secure and solid, and can be removed with a handle when I want to stow my laptop, IPAD, other valuables on a long trip and quicly remove to bring to room. Easily holds full face helmet along with a lot of other things I want to have easy access to like sunscreen, windshield cleaner, etc. I haven't regretted the choice one time after three years and two long tours, and there are a lot of styles and options. I think the color scheme blends decent with the bike as well.
Enjoy your ride and be safe.
Plant Cloud Tire Sky Wheel
See less See more
Reactions: 2
I would say the OEM trunk does more than just sit on a carrier with 4 bolts! That being said I am thinking of a Shad 46
Font Audio equipment Music Screenshot Event
See less See more
Enjoy your ride and be safe. View attachment 283799
That actually looks pretty good. Yes I agree on the ease of popping off the case to bring it to a secure place. I've used Givi on several different sport touring bikes. I was mostly looking for on advice about installing the OEM trunk myself. I've alway done lots of maintenance on many of bikes, but this install seams daunting. I'll be sure to wave if our paths cross. Thank you.
That Givi looks really good on your bike.
Is that a Givi V47 Monokey? Have you had any issues with build quality, water resistance , or sun fading.
Automotive lighting Automotive tire Vehicle Automotive design Motor vehicle
See less See more
1 - 20 of 26 Posts
