Hi, I own a recently purchased, 41,000 mile 94 wing. Saturday I rode it on a cold outing. Temps stayed between 14 and 30. Two problems came up. With the CBs squelch turned all the way down to either extreme, the CB always showed "RX". If someone was close I could hear them and transmit to them. The radio has worked flawlessly in the past with the squelch setting rarely needing adjusting.Second, the cruise disengaged by itself and would not reset, but the cruise stayed on. I cycled the clutch, tried it in both 4th and 5th gears, lightly applied pressure to both front and rear brakes, no luck. I shut the bike down, restarted the bike and then the cruise would not even turn on. This 200 mile round trip was all interstate riding. Is 20 degrees (F) cold enough to cause electronics to fail? Your input would be greatly appreciated as I am basicly new to wings. All I know is that I have put 4,000 trouble free miles on the bike without a glitch.
Thanks,
Gene
Thanks,
Gene
