Trying to install a J&M CB radio and can't get the lever off. I took it off a couple of weeks ago but it removed the shaft and disc with the cables on it. Had to take it to a shop to get it put back on.
The J&B installation says to removed the bolt in the center and remove the lever but again it will not come off without bringing everything with it.
Do I remove the screw that holds the spring on?
Thanks for any help.
GD,
Suggest you go to your user cp and complete your signature with the year and bike ex.. 99 SE. That way, when you post a question, others will know which bike you have. I will get your questions answered quicker and you won't have to remember each time to post that same info over and over.
88-2000
Typically, the rubber boot slides off and exposes a bolt. On removal of the bolt, pull the lever towards you to get it off the shaft. Sounds like something else was going on internally before.
personal cp
First off, I don't know where to go for the personal cp. When I click on what I thought would take me there I got to this post. Little help please.
Discussion Starter · #4 ·
update cp
Spoke too soon. I found something that filled in info but it left off some also. What gives.
Go to:
User CP
Edit Signature (down on the left)
Add or change information in box
Scroll down until you see the "Save" box
click on "save"
:eek:
Another way of adding your bike info is to tag it along with your " location " information. You have done that, so just add your bike info to it ( note my location info ). An avatar picture of your bike can help to a limited degree also.
