Does Honda support older Goldwings (1500/1100) with detailed information online? If so where?
Once a used Gold Wing is bought, for someone that is willing to try some preventitive maintenance ( but not all), what reference material would you suggest purchasing? Is the original owners manual enought to change oil/filter, air filter, grease needed bearings/shafts, top off any coolant, remove gas tank to access inside parts, replace lamps bulbs, adjust cables, top off brake fluid, visual inspections and removal of plastic body pieces.
I'm trying to determine how much money I should hold in reserve for hardcopy info. and inspection by a professional Honda mechanic.
Dan
Dan
