1 - 19 of 19 Posts
Road Pegs
I'm 6'1" and also need to relax my legs, usually after about 130 miles of running. I purchased the Kuryakyn Ergo Pegs; but they did not do the trick. When I put my feet on the pegs my inner knees hit the fairing; I felt like my knees were up too high and just couldn't get comfortable.
I tried to adjust the pegs by lowering them, bad choice. Fifty miles after the install, I went around a bend and scraped the pegs, (almost tipping over) they were too low. (Need to follow instructions on these babies) I solved my problem by purchasing 2" 1/2 in peg extentions. The extentions moved the pegs out and I was able to put my feet on the pegs without hitting the fairing; however, I don't feel like they are as comfortable as they should be.
Total spent on this effort was over $300.00 dollars. When I'm feeling good, I play around with the settings trying to find the best position.
Suggest mounting whatever pegs you're looking at before buying them, I wish I would have.
I have the Kury Ergo's and boards on mine and I've got them adjusted where I like them, but you've got a bit more inseam than me. I had pics posted somewhere, and I still have them on my desktop, not saying it's what might work for you, just fyi. If you look at the angle on the arms, it's fair steep, and I really haven't dragged them at this setting, dragged some other stuff tho:
Discussion Starter · #7 ·
Do the boards interfere with the side kick stand?
The Kuryakin mini floorboards no, not really. I use my boot toe and flip the stand out no problem. Full boards do though, I think some riders say even with the stand extension, they get in the way. Othr than they don't match all that well, I have no complaints on the mini boards.
I love my Highwayboards as pictured on budoka's bike. However, if your inseam is about 32 .in. or longer ( tape measured from the heel of your boot to your " center pocket " ) plan on spending an additional $44.00 on the shorter arms. Once I put the shorter arms on mine I was HAPPY. Don't ask me why Kuryakyn does not offer the shorter extensions with the original order because all you will hear from me is complaining to the wind.
That's likely something else I have to think about doing, the shorter arms. My knees are pretty flexed the way they are now. Still better than not having them though.
That's why I opted for pegs instead of Boards. Got these guys you can move them all around the crash bars & complete 360*. Plus once you get them set you can either toss your foot all the way on top of them, put your toes on them, or the ball of your foot (mutiple positions).
I'm just saying.:eek:
http://wingstuff.com/pgroup_detail/.../gl1800/232_goldwing_Footpeg_Floorboards/des/
With the original 6 in. extensions the boards were so far back that I could never have my boot heal touching the highwayboard heel ridge. The extension arm is level with the crash guard and the board is tilted upwards to the first incremental position. They are corner scrapers in tight aggressive turns, but that's not the fault of the floorboards. It's amazing what a simple 1.5 in. reduction in length did to change my leg comfort posture. When I add to this the 1 in. up/back bar risers it will be as good as it can get for those long slab rides to PA.
Thanks a whole bunch chopin, I just got my LED fog lights and backrest and I gotta spend more coin! C'mon Lotto Max!!!!
Remind me to get a picture of fossil's boot heels resting on top of his foot pegs going down the highway.
You have seen it buddy. You can attest that I don't lie.
Nothing like strecthing out & relaxing on the wheels of a wing.:D
www.ridingiswonderful.com
Go there and take a look,not cheap but very comfortable without making a wishbone out of yourself.
1 - 19 of 19 Posts
