1 - 3 of 3 Posts
I am brand new to this forum as I have just this spring picked up a 1975 Gold Wing. I love it! It's something I have been wanting for a very long time and finally have one. I am experiencing a hesitation on acceleration between 6&7000 rpm. I just had electronic ignition installed. the bike came with carbs off an 1100. I swapped out the fuel filter, the timing and carbs were checked when ignition was done. Any thoughts?
while idling spray some starting fluid are wd40 around the boots and the manifolds where they bolt down to the engine see if you get any engine change ..at that rpm i would it has to be air from some where ,,it red lines about 6000 but that engine loves rpm.
@kgee
I highly doubt that this gentlemen will heed your advice, since his last known activity was over 9 years ago. :unsure:
1 - 3 of 3 Posts
