i cut the wires after reading a earler thread and got back on the road when i got home i tryed to clean up the wires and make it neet now it is not charging could i have got the wires mixed up how do i tell wich wire goes where the look all the same color or am i just blind
There is no wrong way to hook them up. They are all the same color. Just make sure you have good soldered connections and none are touching ground.
Report back with the findings.
The Limited needs all the power it can get and has a special stator, it cannot use a regular GL1200 stator or reg/rec.
You may have a reg/rec that went bad.
