help with flashing dash lights
104 Views 3 Replies 2 Participants Last post by  GLblinded
jacked up my 2021 Goldwing Tour DCT to put on a new front tire. When I was done on the test drive the transmission started shifting strangely the HSA blinked amber. the Torque Control was blinking and the ABS blinked, drive indicatour and the Tour blink and show as asterisk and I could not accelerate above 40. What can be wrong? Need help when i would let off and then try to speed back up it would work for a while then the Torque control light would come back on a b slow down again? any info would be helpful.
I’m only guessing here, but something with abs on the wheel is causing your issues, recheck your work carefully.
Reactions: 1
Fixed and working great again.
I found that I had tightened the pinch bolts before the axel was completely seated.
reseated the axel torqued it correctly and then tightened the pinch bolts, problem solved.
the axel was only off by less than a 16” but what a difference. Thanks to everyone for all the help.
Marshall
Reactions: 3
Marshall
Bet that feels good.
Reactions: 1
