1 - 20 of 22 Posts
I have attached a couple of photos I attempted to get to show where leaking is - you can see the spot on the ground. I also tried to take pic underneath bike, but that was hard - not to clear. I see color on paper towel is pale green so I'm thinking it's antifreeze??? After heating up bike for 10 mins I hear a faint repeating whirring noise coming from that area - is this the water pump???? I just want to get an idea before I have tow come to take to shop which is 40 miles away, so I may have an idea what I'm in for. Any replies and suggestions will certainly be appreciated.:confused::(
The water pump is more towards the center of the bike. I'd check your hoses and connections.
i hope you don't have a blown head gasket
Gosh, I hate to think of such expense for what might just be 1-2 turns of a lower clamp srew!:eek: Then again my cheapness is well established!:eek:
Hopefully it's not too expensive or serious, best of luck. What year is your 1500?
Chased small coolant leak,a long time. Smell of antifreeze was how i knew it was there. Then on floor, after much frustration found baked o ring's on water pipes was cause of leaks. Not hoses, pump,radiators, or other things. You could see stains on top of motor, after you removed front side cover with a good flashlight. Hope this helps you
GYPSYGAL,
Please let us know what the shop finds, I think I have a small coolant leak in my 1500 as well, I smell antifreeze occasionally, I don't see coolant on the ground yet but when I warm up the bike in the mornings sometimes I also see smoke and smell coolant like it is burning on the exhaust pipes when it is left on the side stand over night. I am just monitoring my leak right now keeping an eye on the over flow tank to see how fast the coolant disappears. Mine appears to be small.....at least for now.
Another source of leaks on the 1500 is the tape that Honda put on the radiator and water pump tubes, it dries and cracks after years and coolant weeps through the cracks in the tape. If you remove the front cowls and radiator schield see the connection.
Chances are the O'rings are your leak.Pull your front side cover off, left & right, shine a good source of light behind plugs on the top of the motor. Chances are, you'll have coolant stain's, look till you see chrome pipes, running side to middle. That was the source of my leak's. Quite a bit of dissambly, but not that big of a deal, if you don't like the smell of coolant.Left side was the worst, but you don't loose much coolant more of an irration, than any thing else. triwing
Discussion Starter · #15 ·
Unfortunately for me, the shop says I need a water pump for my 1999 GL1500SE - on top of that they found that my clutch fluid was leaking on to the exhaust too! I have absolutely no motorcycle mechanic skills, aside from checking my oil and tire pressure, so I have to rely on a shop for repairs. Thank you all for your advice and comments.
Discussion Starter · #17 ·
Hey Triwing - clutch slave cylinder being done over too! Water pump, o rings, shifter shaft, exhaust gaskets, muffler gaskets, etc. Many $$$$$ but I can't do it myself and I love my Goldwing trike! I live on the coast in SE north Carolina and I can pretty much ride my bike all year and I miss her already! Next year will definitely be better!!!
Make sure they get the muffler bearing reinstalled correctly!
When one is lacking in mechanical skills it pays sometimes to act like you know enough to ask to see what they found even though you may not know what you're looking at. That can sometimes catch fraudulent charges. I'm convinced it still happens occasionally where and when the opportunities arrises.
Sounds like a failing RH coolant tube O-ring IMHO.
1 - 20 of 22 Posts
