I appreciate the help, did some research and on mine it is a little diffrent because of the heated grips and seat I guess, anyway getting ready to work on it now, when I work on this thing I think about how easy my old Vulcan 1500 was too work on compared to the wing.Unless they changed the design in the 2012, if you're looking at the plug from the right side of the bike, the tab you see needs to be pushed down ( compressed ) and the two connectors pulled apart. It is perhaps the most annoying connector on the Wing. Anything from a pair of long needle nose pliers to surgical clamps to compress the tab will aid and abet.
I see you are running a car tire, how do you like it? I am thinking of going that way, I only get about 9,000 mi out of a rear bike tire and have put 13,000 on my bike in 5 mos so I would like to try something that would give me more mileage.Unless they changed the design in the 2012, if you're looking at the plug from the right side of the bike, the tab you see needs to be pushed down ( compressed ) and the two connectors pulled apart. It is perhaps the most annoying connector on the Wing. Anything from a pair of long needle nose pliers to surgical clamps to compress the tab will aid and abet.
Son-of-a-gun. The more things change , the more they remain the same. I would hope at least they figured to rotate the connection disconnect tab 90* to make it more visible and obvious.Connector still the same on the 2012 model. I just unplugged mine yesterday to remove the panel to install handle bar risers. So still the same.. Good luck.. it's not for the faint at heart...
Best ride I have had since I first got on a Wing. It may not be for everyone, but it was a natural for my riding comfort and type of riding. I'm happy. Only have a bit over 4,000 miles on it so far. Looks brand new ( albeit I don't have a depth gauge yet ). Very quiet and smooth.I see you are running a car tire, how do you like it? I am thinking of going that way, I only get about 9,000 mi out of a rear bike tire and have put 13,000 on my bike in 5 mos so I would like to try something that would give me more mileage.
Got the harness apart happy about that as far as the tire goes 9,000 may seem low to you as well as to me but thats all I got out of the original rear tire, the only thing I can think of is a lot of times we hit the interstate and run 400 or 500 miles a day. Anyway not happy with it and thinking of a C/T but that screws up your warranty on anything on the back end of the bike or so they tell me at my Honda Dealer. Thanks for the reply, ride safe.Curious Johnnie1, what are you up to that you have to pull that harness apart? Do you pull a trailer with your bike? 9k is a bit low for rear tire mileage (I think), I've got 12k on mine and it's not ready for the heap yet. C/T is making more sense to me though, compared to how I used to view the subject![]()
Ok got the wiring harness apart Yea. Thanks for the information may go to a car tire but was told by my dealer it would void my warranty on anything on the rear of the vehicle. Still think it might be worth the change. Anyway thanks ride safe and ride a lot.Best ride I have had since I first got on a Wing. It may not be for everyone, but it was a natural for my riding comfort and type of riding. I'm happy. Only have a bit over 4,000 miles on it so far. Looks brand new ( albeit I don't have a depth gauge yet ). Very quiet and smooth.
Check on that. Sounds like a provincial threat. Your Warranty is good at any Dealer, providing the Dealer is " good "......... but that screws up your warranty on anything on the back end of the bike or so they tell me at my Honda Dealer. Thanks for the reply, ride safe.
Been both there and done both of that. Good for you. Which risers did you get ?Really appreciate everyones reply on this, got it apart now ready to install the riser's, next thing may be too change the air cleaner woo-hoo. Have a good day and stay safe.
