First thing Ole G welcome to the forum. I only know of one way to get a key made for your bike, and that is to remove the ingnition barrel and then take it to a dealer or a locksmith to have a key cut. There should be a 3 digit code (1 letter and 2 numbers) stamped on the side of the barrel. Be careful because there is sometimes also a numerical code with 3 or 4 digits but this is not the correct code. The reason for removing the barrel is not only to be certain you have the right code, but the keys that get cut are often not perfect and don't work, so you can try it to make certain. Dealerships can only order the blanks from Honda, and then cut them if they have a key cutter. It's one of those things that some shops don't care to do, as it's usually a net loss scenario by the time time, freight and failure rates factor in. A key will only cost around $10, if you replace the barrel (100% effective) you are looking arouind $100 (Cdn prices; US?). Good luck.
