Hello there,
I just made an agreement to purchase a 1982 Goldwing today. This will be my first Goldwing and I am curious if any of you can tell me anything I may want to be on the look out for.
I currently own a 1983 Yamaha Venture and it has certain known issues that I have had to deal with and I am curious about the 82 Wing.
I didn't have a whole lot of time to research this bike but the price was right (I am only paying 500 for it). So I would appreciate any advice. The bike has been sitting in a barn for the past 5 or 6 years so in addition to the general fix up stuff is there anything I need to know. As far as I know it was running when it was parked but obviously is going to need some work to get running again.
Anyway, greetings to all and I look forward to hearing from those of you who are experienced in the ways of the Goldwing
Brad Schmidt
... Howdy ... Here Are A Few Things You Will Want To Know ... Have The Belts Been Changed And What If Any Repairs Have Been Done ... I Will Leave This Info. Here And Let Others Post Their THOUGHTS ... Happy Trails ...
If the bike has been sitting in a barn for 5 years you need to check if any critters have been chewing on hoses or wiring. Drain the fuel out of it and fill with fresh stuff. Most of the fluids should be drained, like oil, clutch and brake fluids and radiator. Once you have the fluids changed and a new fully charged battery give it a try.
Check to make sure the brakes are good and rotors are okay. Probably will need a fresh set of tires. Now your ready to ride. Enjoy and be safe...
... HOWDY ... TIRES ARE A MUST REPLACEMENT ... A LITTLE KNOW SECRET IS TIRES ONLY HAVE A 6 yr. SHELF LIFE FOR SAFE OPERATION AND THIS INCLUDES CAR AND TRUCK TIRES ... ALSO WHILE DOING FLUIDS CHANGE THE RADITOR HOSES ... HAPPY TRAILS ... GOOD POST ABOUT THE CRITTERS 2-WHEEL ...
My Son just finished putting an 82 Aspencade on the road that sat for 5 years,he paid $500 for it as well. It would'nt Idle properly. He took the Carbs off cleaned them out properly put them back on and now it runs okay. The choke cable is stlill tight, he reaches down and trips the choke on the carb by hand for now.He adjusted the valves and put 20-50 oil in it which quietened it down (NOT SYNTHETIC OIL) Synthetic is too slippery and screws up the clutching. He added Satellite radio to the onboard Stereo and now he's got himself a good full Dresser to run along with my 85 GW Limited Edition :) A tip: crack the drain screw one at a time on each Carb. at the beginning of each season and let some gas drain out, it helps get rid of the stale gas,I Always did that on my 83 Interstate.
Robert
Terrace BC Canada
... Howdy ... Bstar ... Made A Good Point About Stale Gas ... With This Crappy Fuel We Get These Days Make Sure To Use A Fuel Stabilizer ... I Use The "ethanol Stabil" ... Happy Trails ...
First thing I would do is find out why it was sitting so long, most 1100 & 1200's will have stator problems, except the SEI models which had a bigger stator. If it is bad or if the stator has never been replaced I would replace it while you are doing all the other work. I had one on my 85 go out at 49,000 miles, had a friend with an 85 and his went out at 15,000 miles and others went iver 70,000 miles but you can be sure it will go out. There is a plug next to the battery, check it and se if it is burnt, or starting to burn.
hello and welcome to GWOF
