1 - 2 of 2 Posts
I have an '07 GL1800. The heated grips worked fine during the last winter but this year when it turned cool, they don't work at all. Checked the fuses in the fuse box beside the battery and they were all good. What else should I check before taking it back to the dealer for repair?
I am sure you have chased the wiring and ground wire. but if not try that. If you find the plugs on both sides you can put an OHM meter on it and see if the heating elements are good. If the elements are broke you will get a zero reading. If there are good you will get reading of anything above .5 and up.
1 - 2 of 2 Posts
