I just got a 1985 GL1200 Aspy. I would like to listen to the radio via my helment headset. Can someone tell me which wires can provide me left and right audio when you select HS on the radio? I plan on putting a mini audio connection on the wires.
Discussion Starter #2
I found the audio jack pushed down into the wiring, now I have a different question. Does anyone know if anyone sells an adapter to connect to a standard sterio connector (male or female).
Does anyone know were to get an old audio haedset cable that is no longer good. I need to find a connector for the heatset connector. I need a 5 pin down female connector so I can wire up an mini sterio connector to it.
Wouldn't it just be easier to buy a J&M headset?
Discussion Starter #5
No I have two helmets with headset installed (no Mic needed) and I have 2 Bikes. I use a audio connect to listen to MP3 and GPS. I want to use both helmets on both bikes
