I have a 1983 Goldwing 1100 Interstate and my headlight recently went out. i have tryed several new bulbs and it still dosent work. i think maby its a fuse or faulty wiring due to the age of the wires? any information would be appreciated thanks
Somebody on here probably has a wiring layout for your bike or know where to find one and I'm sure they will chime in here with some help. Sounds like you are on the right track.
I believe there is a relay that shuts the headlight down during start-up. I don't have the wiring diagram for an 1100, but I'm sure somebody does and will be kind enough to help you out.
Check to see if you have power coming into the dimmer switch (hi/lo beam switch).
Blue/white and white wire for low beam
Blue/white and blue wire for high beam
Check at bulb socket Blue to ground for high beam
Check at bulb socket White to ground for low beam
You may have also lost ground (green) at headlight
I cannot see why not, just follow the electrical schematic and look for the plug in harnesses and you should be okay.
