I noticed today that my left headlight bulb is dead ( low beam)
I am at work, and can pick up a replacement for the ride home.
Can anyone tell me what I need? I think I can this at a car parts place maybe?
If it's an 1800 Gold Wing you need an H7 55 Watt bulb
When you take the old bulb out be sure to take the adapter off the bottom of the bulb. You should replace both low beams at the same time, if 1 went the other is sure to go soon.. Also do not touch the bulbs with your bare fingers.
So the next question is can I put a higher power bulb in her with out any damage to the surrounding plastic fixture?
If I do this will it add too much drain to the battery?
