I have a 94 Aspencade, what is the easiest way to replace the headlight bulb? I would like to replace the stock one with a brighter one. Thanks for any sugestions.
Remove the garnish (chrome) nose piece. Pull the mirror boot back and you will see 2 screws on each side. Remove them, and then slide the garnish to the right and it will come off. From that point it is just remove screws. Be careful, there are some sleeves on a couple of the screws you will need to replace.
Hope this helps.
:rolleyes:Like GoldDigger said, there isn't and "easy" way
Discussion Starter #5
Thanks GoldDigger, I'll probably be giving that a try along with trying to fix my bogging down on load I posted in new member.
