1 - 2 of 2 Posts
Hi All
Not sure if this topic has bee raised before, hopefully not, I need to replace the bulb on my 86 Interstate but I can't work out how to do it, I've found how to undo the two bolts at the bottom of the headlight but I'm at a total loss on how to get the top bolts off, hope someone on the forum can help, coz I'm losing a lot of riding time before our cold an wet sets in. :confused::confused:
hi hills, start by removing both mirrors, 2 bolts each located under the rubber garnish, than remove the windshield garnish[the chrome cover that goes from mirror to mirror] sometimes it helps by slightly prying up on the garnish between the headlight and garnish. you will then see the top two headlight mounting bolts to remove. good luck
1 - 2 of 2 Posts
