There is always some new maintenance product available, has anyone tried this?
That means I cannot use it on a 1993.That, sadly, cannot be used in the pre 1999 Wings as it contains coladromite.![]()
Someone else will have to try it.Ladies first. I'll wait for your review.
everyone knows you can't use blinker fluid in the head light sillyUnfortunately, you can't mix that with Tungsten OR Halogen headlight fluid!![]()
Check with your proctologist.HEY, that's the stuff I use in the final drive...... Maybe that's why I'm getting a loud HUMMMM from the rearend.... Do they make that in a 90 weight?????
Made an appointment for September. Thanks for the advice...Check with your proctologist.
Well that explains why the cannebling pin seal on my 93's fourway flashers started to leak. Wish I had known this sooner.That, sadly, cannot be used in the pre 1999 Wings as it contains coladromite.![]()
If you can afford a new wing, you can afford this.This looks like a great item for the new 2012 Wing.
http://kalecoauto.com/index.php?main_page=product_info&cPath=6&products_id=28
May not work on the GL1500.
